first question is, would a faulty O2 sensor or connection cause my issue?
Thanks in advance
Matt
GTMatt wrote:Yeh CEL.Tuner didn't know to hand the fault code so is looking into it.
I have also posted on the link forum to get there input.
I can check the error log as I have no laptop or usb harness.
Just taking the symptoms into consideration in your experience/ opinion can the fault be narrowed down? aka tps, map sensor etc etc?
GTMatt wrote:Managed to get the car idling on its own without throttle input so I could look in the engine bay, and I noticed my Hks ssqv is blowing air at idle.Am I correct in thinking this could be the source of my problem? Aka a massive vacuum leak?
Matt
