If anyone is having trouble with their front indicators and reflectors not staying in very well, then you are probably missing the grommet and screw that hold them in.
I had the same problem and just thought I would post up the part numbers of the parts to order from Toyota.
Grommet - T90189-05050
Screw - T90168-50050
You will need 1 of each per side.
Total price for 2 of each is £6.17 from local dealer.
Hope this helps someone else out.
[Mk2] [Generic] Front indicator separating - Part No. of grommet & screw inside
Re: [Mk2] [Generic] Front indicator separating - Part No. of grommet & screw inside
This is pretty useful because I have two sets of sidelights that dont bloody sit properly!
