Ok.
.I maybe way out of my depth here but here goes:
If you take two pieces of material of an arbitrary thickness and clamp these together with a standard bolt and nut
- where are the maximum forces at work?
With a bolt and nut I think the maximum force is directly underneath the head of the bolt and underneath the nut.
Now.
.when applying such loads it's a good idea to spread the stress over a large area.
.eg.
100 pounds of pressure on 1 square inch is more stress that 100 pounds of pressure on 10 square inches.
.but how can we spread the force when clamping parts? Well if I have threads in the parts then the force will be spread over the surface area of the threads which is a multiple of the area underneath the bolt/nut.
The problem is I can only screw into one piece of material.
.I can't screw into both and still generate a clamping force.
So.
.In modern engines the clamp load is distributed in the block via the threads and concentrated in the head under the bolt/nut.
Now taking the drag racer as an example: if I bore all the way through and thread a nut on the other end I haven't won much.
.The load is now directly underneath the head of the bolt and underneath the bolt at the other end.
If I instead
use a girdle that uses
'n' bolts to press some kind of frame onto the head and at the same time press a frame against the bottom of the block, then I have a real gain in structural integrity.
On a side not you cannot bore a gen2/gen3 through completely.
I'm pretty sure the threads for the bolt for cylinder 4 intake side ate outside of the normal block.
