Can anyone please give me some insight as to why I can't seem to plug the following into my new starter motor? It doesn't appear to be the correct cable or am I missing something here?
[Mk2] [Turbo] Starter motor cabling query
Re: [Mk2] [Turbo] Starter motor cabling query
That first one should plugin to the starter ... it did on mine
Does the second picture look the same as was on your starter??
Never seen it before mate ..... rev1/2 turbo .
cut the plug off and replace with a normal sized spade connector and it'll fit. Or transfer over the assembly from the old motor.
Cable looks right. Starter look wrong.
Do you know what sized spade connector I need and how they attach?
Legit wrote:Do you know what sized spade connector I need and how they attach?
Why not get the right starter?
It's supposed to be the right one though! Got it from this here: http://www.ebay.co.uk/itm/TOYOTA-CELICA ... 3f462ac6e0
I'm assuming this was a bit of a fail on my part then?
Legit wrote:It's supposed to be the right one though! Got it from this here: http://www.ebay.co.uk/itm/TOYOTA-CELICA ... 3f462ac6e0
It' a fail on their part. The pic in the auction is not a SW20 starter motor.
OK matey, cheers for that. Best place to get a good used/new one?
Legit wrote:OK matey, cheers for that. Best place to get a good used/new one?
MR2 Ben or GTS Chris. Both good used spares stockists.
Used them both before, got one on order now
