Heat reflective tape?
jimGTS
Post by jimGTS »
Hi in the process of adding an additional heatshield to keep bay temps down as much as possible, to help even further id like to add some heat reflective tape on the underside of it.
Good cheap suggestions that wont peal off?
C35Rob
Re: Heat reflective tape?
Post by C35Rob »
DEI reflect-a-cool, the gold stuff if you're a pimp.
I have got a source for some generic copies of the reflect-a-gold, but i've not tried it myself yet
Had this done to mine. Stock heatshield wrapped in Nimbus:
2mad
Post by 2mad »
Yes ^^ , what Red suggested :thumleft:
jimGTS
Post by jimGTS »
I dont care too much how the tape looks as itll be on the underside.
The shield ive made is polished! So thats enough bling already.
Way i see it, if theres some distance between 2 heatshields, then it will work much better than 1.
2mad
Post by 2mad »
Peter Gidden
Post by Peter Gidden »
"Can Withstand Direct Heat Of Up To 200°C"
Good luck with that 5mm from the hottest component in the whole car.
Nimbus II is used to insulate from turbo/manifold heat sources on F1, WEC and WRC cars, as well as jet engines.
For the most extreme heat, choose the most extreme solution.
2mad
Post by 2mad »
I would use Nimbus II Pete .. my other suggestions the next best thing from looking on the net .
Peter Gidden
2mad wrote:I would use Nimbus II Pete .. my other suggestions the next best thing from looking on the net .
That's the "problem" with Nimbus II. It's so good, nothing come close.
Why not use Nimbus II jim? Seems the simple solution.
dan mkii
Post by dan mkii »
I used the stuff from halfords very cheap and has been on a while and not come off
jimGTS
Post by jimGTS »
Bare in mind i am still using the stock heatshield as well.
The new one there is a good 50-70mm away from the original.
So it should be getting less heat. 200c may very well be ok.
Peter Gidden
jimGTS wrote:Bare in mind i am still using the stock heatshield as well.
Why add another heatshield when one modified properly will look professional and do at least the same job? :?
Certainly a lot cheaper but depends where your priorities lie I guess.
Jim, the answer lies here:
RedMR² wrote:Had this done to mine. Stock heatshield wrapped in Nimbus:
jimGTS
Post by jimGTS »
How does something like that work when its in contact with the heatshield.
It will be radiating the same heat the heatshield is surely as its metal on metal?
If it was spaced away im sure it would be more effective.
QUOC2008
Post by QUOC2008 »
Where can get these nimbus heat shields from?
MR2 REV 3 TURBO 450BHP
3000GT VR4 TT 500BHP
EVO X FQ360
slipping clutch
Post by slipping clutch »
QUOC2008 wrote:Where can get these nimbus heat shields from?
You buy it as a sheet form it and cut it yourself over the existing heat shield.
