Has anyone used this brand or would you recommend either of these over the standard exedy clutch?
On another note, where's the best place to get a replacement gearbox as mine is whining a treat and is linked to input shaft bearings.
bobhatton wrote:The clutch is not an easy thing to change and if it goes wrong the work has to be done again I would keep clear of cheap parts made in China and go for a stock Toyota one.
Race Idiot wrote:bobhatton wrote:The clutch is not an easy thing to change and if it goes wrong the work has to be done again I would keep clear of cheap parts made in China and go for a stock Toyota one.
So a daikin/exedy one then.
bobhatton wrote:
Not one I would ever use, Toyota if a stock engine or one made in the USA for an upgrade like Act etc.
