As I say I have done alot of research and I know the blocks are the same as in both are 3S blocks and the last part of the engine code denotes the cylinder head used, be it Toyotas
Some obvious issues will be that I will need to get an ecu which will need retuning as the compression ratio is going to be around 10:1 higher than any of the turbo versions but lowest of the non turbo's and then will I need to upgrade other components?
The good news is the wiring loom appears to be identical and I have already upgraded the cooling system, suspension and brakes.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Your thoughts and sensible advice would be appreciated.
