Anyway i feel that rot is the number one killer of our cars, this more than anything is going to despatch them in their hundreds as solid repair sections run out.
Aside from the usual rear arches, sills and chassis members
The car in question i am repairing is an average Mk1, with good arches, sills and not too bad everywhere else, but with a totally rotten top screen/roof section.
So i've repaired Mk1 roof sections this way a number of times in the past, but thought now would be a good time to document it so that others know what they are up against and hopefully save a few cars in the process.
This is the section of roof in question, the screen has already been professionally removed and the rotten section of roof cut out.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-11-18132209_zps94b924a3.jpg)
You can see we at least have a solid bottom edge, for the purpose of this guide i am going to assume everyone at least has this, if this is rotten too then it really is time to assess the whole car as a viable project.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-11-18132125_zps76f43337.jpg)
The first step is to buy some 20mm angle 1.2mm thick and make slices in one edge every 20mm or so, this will let you contour the top edge around the roof.
Careful tacking needed while keeping the outer edge in line with the lower panel to ensure the roof edge is not lost.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17105131_zpsd3e5316a.jpg)
As you can see this has only been tacked to the upper edge, not the lower, we will be making another repair section for the lower half.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17105142_zps1ed3f27c.jpg)
Here you can see the nice sweeping radius of the roof is back to how it should be.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17105153_zps1253da61.jpg)
The next stage is to make a lower repair section, using 10mm angle, 1.2mm thick, this is again sliced along one edge and given intermediate slices on the other edge, then drilled for spot welding.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17110210_zpsf030df6a.jpg)
With this lower section welded in, the upper slices are welded through to the lower repair and all welds ground flat, i use a 40 grit flappy disc for this as it has much more control than a grinding disc.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17120819_zps6bbcc263.jpg)
That is the structural side taken care of, the roof is now 100% solid, and probably stronger than it was originally as the vertical face is now double skinned.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17120753_zps3029181a.jpg)
Now to make it cosmetically right, if you've taken time with the welding it should only require the bare minimum of filler.
My first skim, probably only 1 or 2mm thick.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17141135_zpsac0b6b03.jpg)
This is sanded back with a bodyfile and 80 grit to reveal any high or low spots.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17144907_zps66ca63b6.jpg)
A second skim then takes care of any remaining problem areas, now it may take you 3 or 4 skims to get it right, i've been doing this all my working life, so i'm awesome
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17141200_zpsfe20d954.jpg)
After final sanding, you don't need to use finer grades, if you use a 4+1 high build primer
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17152049_zps793eea62.jpg)
One totally repaired roof, and it cost
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%209/2014-12-17150808_zpsec67c01b.jpg)
This just requires wet flatting with 240 then 800, then 1500 grade before painting, it is also a good idea to waxoyl the inside of the repair from the cabin to prevent the welded repairs causing a future problem.
Hopefully someone will use this guide to save their Mk1.
