I know it seems like a worst case scenario, but i had the same symptoms
Once i knew, i took the ECU apart and found one resistor fried.
MR2shane wrote:Hi,
I know it seems like a worst case scenario, but i had the same symptoms(albeit on a 1992).
.ended up changing every spare part i had
(& knew worked), ignito, coil, dizzy, leads, plugs, earth cables, fuses etc etc.
.until i ended up changing the ECU and she fired straight up.
Once i knew, i took the ECU apart and found one resistor fried..
.i havent bothered fixing it yet now its all running, but maybe something to check.
bigal wrote:MR2shane wrote:Hi,
Yes, definitely check your ECU for leaking capacitors.
Take your ECU off and have a look inside its a nice easy job and doesn't cost anything unless you find the leaking capacitors which are a well known fail point.
It cost me
£40 to have mine repaired last year and I've had no problems since.
2mad wrote:bigal wrote:MR2shane wrote:Hi,
It cost me
Agreed.
this happened to me
my engine check light used to come on for no reason
two big capacitors and leaked there electrolytes all over the circuit board.
well worth a look
ecu was a rev2 tubby
