Shift Cable Bearing Kit £9.70
Re: Shift Cable Bearing Kit £9.70
Hi interested in a set of these
Interested too!
Can you pm me payment details peter?
how much difference do they make? and are they a straight forward swap? will possibly get some in a few weeks
They are a straight forward swap. I did have a little difficulty getting my old ones out but if you pour a little oil on the middle.. then do the twist it should eventually come out. then simply follow the instructions that come provided.
The middle of the rubber on my old ones had gained a oval shap which meant there was much more movement in the bush than there should have been this caused the gear changes to be I can best describe as wobbly.
Once the new ones we installed changes became smooth and gave you a reasurance that you've selected the gear.
All in all a simple job and this kit litterally comes with everything you need to get the new ones on.
For not a lot of money this has to be the best mod i've done.
Plus the instructions are written so simply and easy to understand.
All enquirers PM'ed.
Thanks David!
Thanks David!
Hi Peter , still waiting for this kit, the payment was included in the payment for the Prothane bush kit that I purchased from you about three weeks ago. I've tried pm-ing. Cheers mate.
- IMOC Moderator
You still have these in stock Peter?
Still waiting.
Received, many thanks.
Just ordered another set for my EP91 Starlet..
Are these still available
Bump
Bump
I'm also interested.
Sent a pm.. awaiting reply..
Received.. looking forward to fitting them!
Pm'd you Peter for a set of these shipped to Canada, please let me know.
Are these still available?
After a set if still available
