just got mr2 back from Xxxx @ Banned trader.
Here some pictures
Im have issues with the engine lid the hoses are touching the lid... any advise would help
Post edited by Mod Team
just got mr2 back from Xxxx @ mr2developments
Re: just got mr2 back from Xxxx @ mr2developments
Take it back to Xxxx?
Looks like a monster, but the little details if not fixed will become big ones.
Just being nosey, what power are you running? What's your build?
- IMOC Moderator
Peter Gidden - SBITS wrote:Take it back to Xxxx?
yeah pretty poor show letting you leave with such a stupid issue, take it back, the pipes need moved
That looks a beast..! Be interested to know spec / power.
Pipes wont be hard work to adjust in order to not hit the underneath of the lid.
Alternatively get an ASK SPORT STYLE engine lid fitted from Carben Creations it will IMO suit the car and give you plenty of space under the engine lid.
Or a black phoenix power engine lid
PM me if interested, I'm only 30-40 mins drive from you to come and have a look
Sorry its not pipes their hoses so not really a issue but im ocd
juliankv73 wrote:Or a black phoenix power engine lid
I was thinking something like that but wanted to keep the oem lid as fibreglass and carbon never last
Im running 1.4bars 445bhp 380lbs on a very hot day no fans and it wasnt finished but spoolup was good 2700rpm peak torque @ 3700 but drops off around 6700rpm
Turbo is hks gt3037rs
Im gonna dyno it again soon
Car looks great Quco, near perfect power for a mr2, lovely stance, roll on next summer
yeah at the moment im driving my evo x as the mr2 is abit to loud for work and likes to copy the way snake moveMartin F wrote:Car looks great Quco, near perfect power for a mr2, lovely stance, roll on next summer
Or my foot weights 20kg and cant seem to drive anymore, need a new driving licence i think.
im gonna buy a book on mr2 for idiots
- IMOC Moderator
can you not sjust turn the chargecooler round a bit so it's on its side?? the water should be under a bit of pressure anyway so should be ok failing that, get 90 degree adapters and pop the on, it would stop the hoses protruding.
Looks okay, what do the air scoops connect to on the inside of the engine bay?
sheppy wrote:can you not sjust turn the chargecooler round a bit so it's on its side?? the water should be under a bit of pressure anyway so should be ok failing that, get 90 degree adapters and pop the on, it would stop the hoses protruding.
Xxxx said its not good to do that as air bubbles can get traped
nickg07 wrote:Looks okay, what do the air scoops connect to on the inside of the engine bay?
Scoop use the oem bolts
- IMOC Moderator
QUOC2008 wrote:sheppy wrote:can you not sjust turn the chargecooler round a bit so it's on its side?? the water should be under a bit of pressure anyway so should be ok failing that, get 90 degree adapters and pop the on, it would stop the hoses protruding.
there would need to be air in the system to have air bubbles, there shouldn't any air at all
sheppy wrote:QUOC2008 wrote:sheppy wrote:can you not sjust turn the chargecooler round a bit so it's on its side?? the water should be under a bit of pressure anyway so should be ok failing that, get 90 degree adapters and pop the on, it would stop the hoses protruding.
I dont know but pwr recommend the same as what shaid said
- IMOC Moderator
ach well, new engine cover then buddy
Your charge cooler should never be the highest point as that is where air will collect. Where is the pump and what way does it pump?
Your highest point should some sort of swirl pot with your fill point and pressure cap.
