Any other options that can be used that anyone knows of?
BALDYMONSTER wrote:On the rubber base of the filter there is a hole present.
Like where a hose should fit in or similar?Should I just blank it off.
The right angled pipe from the top feed that fits into the metal pipe is on but there is a smaller pipe in the same right angled piece sticking out for a hose of some sort.
Just block that as well?
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
