Over the weekend I fitted oil temp and pressure gauges.
I have searched around but can't find much info and was wondering what kind of oil pressure i should be seeing?
When hot i am seeing between 3-10psi on idle and a steady 50psi above 3k rpm.
From running other boosted cars it seems that my oil pressure might be a little low on idle.
I know it is considered a big no-no on here, but i am running 10w60 oil as the car has big mileage and does see some track time and abuse.
