sheppy wrote:Yeah what's this problem? I'm by no means doubting anyone but 9 years on this site and i've never heard anything about this, if anything i'm slightly worried as my tensioner is off as it rattled itself free
It is based on speculation between a couple engine builders I was discussing the 3S blocks with.
.we understand why the Rev3+ blocks crack in the cylinders
(poor casting, and hence inconsistent cylinder wall thickness, proven across 4 dissected blocks).
We also understand why sleeving them doesn't solve it as there is too little material left between the cylinders to resist the forces from the crank,
(and so the deck tends to crack into the top water way, typically between 2
& 3).
The history we as a group had pointed at rev 1
- 2 blocks having thicker, more consistent cylinder walls, but when they let go it was almost always around the water pump casting.
One of the speculated causes was that when the a/c was deleted on these engines, often the a/c tensioner bolt wasn't replaced into the water housing, the theory being that centrifugal forces in that area of the block without the additional support from this bolt may have been helping lead to cracking.
It's certainly no where near a proven fact, just our best guess as we tried to explain the patterns in front of us and I'm kinda regretting putting it out there now.
.expecting to get told I'm wrong!
