jimGTS wrote:Ryanrs made over 400hp on 540s,
Granted was a 2.2ltr I believe.
Wow, 400hp on 540's that is amazing
![Shocked :shock:](./images/smilies/icon_eek.gif)
2mad wrote:JD wrote:I don't fancy running stock fuelling for too long as IDC was at 97% for 1.2bar!
JD, You seem to be the exception to prove the rule, for how long did you run 97% injector duty cycle@1.2bar and your car not go bang
You must have the record for power vs stock fueling with rev3 injectors![]()
I have been running 97%@ 1.3 bar on a CT20b for approx 9 years now.
Granted I dont floor her every where but she has a few rolling roads and a good few spirited early morning drives over the weekends of ownership.
Mind you, she is probably overly serviced and pampered to keep her in great running condition.
Marf wrote:All the pampering and servicing in the world won't help you if you run the engine lean.I'd say you've been pretty lucky
tubby_tony wrote:Granted I dont floor her every where
Marf wrote:97% max duty doesnt leave alot of overhead for overboost, boost on a cold day etc etc
I'd not be comfortable running my car at the limit like that..
I like to be able to use my car like its got an OEM map, i.e.can take whatever I throw at it in whatever weather conditions.
Frankly I'm surprised the tuner left it like that
I'll sticky by my original opinion.Lucky.
jimGTS wrote:Rev1/2s run 100% duty soon as it hits fuel cut boost levels(ie 12psi).
1000s of people over the years have run there cars over this boost level without'fueling problems', or
'running lean'.
Why would it be an issue with 540s on a gen3?
9years is a plentiful example that high duties isn't a problem.
I have plans for a bit more power without the hassles/money and worries of injector and ecu upgrades.
I've been there, done that, the gen3 ecu is capable of a lot more than people give it credit for.
9years is a plentiful example that high duties isn't a problem.![]()
2mad wrote:sheppy and jimGTS are spot on, I ran my rev2 engine at 1bar and 1.1 bar for 6 years with a ct20b and I could easily have pushed it further, after 4500 rpm
(full boost) iirr afr's pretty much went to 10:1
I spent days with a mines ecu so it had fuel maps for higher boost(still 10:1 afr on boost) trimming fuel with a afc and 1:1 fpr to bring it down to 11.5 then 50/50 water/meth on top gave me 10.8 afr and the car went like stink.
I was happy to stick with the 440's my wideband gauge never did anything out of the ordinary to show the 440's couldn't keep up.
After my experience with tuning a rev2 I will be pushing my st205 to around 325/330 i dont want to be greedy![]()
Kev.
Marf wrote:
That's a safety feature.I can bet you anything you like that at 11psi the duty is nowhere near 100%
Marf wrote:
Nah it's just evidence that the owner has been lucky in this singular instance not to create a situation where the airflow through the engine has exceeded the ability of the fuel system to provide for it
jimGTS wrote:9years is a plentiful example that high duties isn't a problem.![]()
JD wrote:I've opened a can of worms..
or is that snails!
