8j
+40s are about as high offset as you'd want to go.
Ideally you'd have
+37 or
+35 region offsets, to give you 3-5mm more clearance suspension side.
Those fitments will fit your MR2, they are a common size set up.
One thing to bear in mind if you're interested
- generally you won't get a 255 rear tyre on without rubbing either arch or spring cup, and an 8.5j alloy is wide enough to take a 245 tyre and lighter than a 9j.
IMO the best compromise between width and weight is 7.5j front and 8.5j rear with 225 front and 255 rear.
Now get up some pics of your new BBS!
