Do you need an uprated fuel pressure regulator for 400 bhp or will the standard one work fine ?
Car is a rev 3 turbo.
[Mk2] [Turbo] FPR for 400 bhp
Re: [Mk2] [Turbo] FPR for 400 bhp
Well I haven't got one in my build, Luke hasn't said I need one
3076
Forged pistons 8.0:1
800cc sard injectors
Link G4
Etc etc
3076
Link G4
Etc etc
Martin F wrote:Do you need an uprated fuel pressure regulator for 400 bhp or will the standard one work fine ?
You need uprated everything for 400 HP
Odin_S wrote:Well I haven't got one in my build, Luke hasn't said I need one
3076
Link G4
Etc etc
what power is your car running ?
bobhatton wrote:Martin F wrote:Do you need an uprated fuel pressure regulator for 400 bhp or will the standard one work fine ?
what are the limitations of the stock regulator Bob ?
The fact its not adjustable!
3076
Link G4
Etc etc
The link g4 will look after yours which is why you wont have one.
Odin, I'm looking at a similar setup, will PM you some questions
simba90 wrote:Odin_S wrote:Well I haven't got one in my build, Luke hasn't said I need one
3076
Link G4
Etc etc
I have a link G3, Guess it is not as good as the G4
Anybody recommend me as to what one i should get ?
Martin F wrote:simba90 wrote:Odin_S wrote:Well I haven't got one in my build, Luke hasn't said I need one
3076
Link G4
Etc etc
I think the G4 does, not 100%, but im sure i read it somewhere the other day
Sorry guys, just read this. My car is still in the process of being built. However I'm aiming for a unstressed 400bhp with room for more much later on.
3076
Link G4
Etc etc
How does the ecu look after fuel pressure? (Genuine question)
Martin F wrote:bobhatton wrote:Martin F wrote:Do you need an uprated fuel pressure regulator for 400 bhp or will the standard one work fine ?
It is not just the stock regulator, it is the fuel pump, fuel flow pipe work. fuel return pipe work, injector rail, so many things need to be right to keep the engine safe. Are you piped up stock or closed head?
ashley wrote:simba90 wrote:Odin_S wrote:Well I haven't got one in my build, Luke hasn't said I need one
3076
Link G4
Etc etc
No idea. Just thought i read it somewhere. Could well be talking out of my anus
This is the Link G4 spec
http://www.linkecu.com/products/engine- ... s/g4-storm
Odin_S wrote:This is the Link G4 spec
And how does the ECU control fuel pressure?
I was hoping you'd enlighten me. Who does uprated fpr? I have a new fuel pump going in already
simba90 wrote: Could well be talking out of my anus
I am afraid you're right - typically the uprated FPRs are adjusted mechanically with no input from the ECU...you set a base fuel pressure at idle, then the FPR (generally) increases fuel pressure in relation to manifold pressure...so more boost = higher fuel pressure.
The stock FPR isn't even adjustable, so I can't see how the Link ECU would ever control fuel pressure.
Aeromotive ftw
