Fitting braided brake lines, quick question..
Leakie Tbar
Re: Fitting braided brake lines, quick question..
Post by Leakie Tbar »
pistol pete wrote:Half way through fitting my new suspension ARBs and brake lines
what have people done at this point? to secure the pipe? or have people just left it
as my old pipe was part of the bracket (rev 5)
I am going to make something up at work to hold it in location, as i don't like it floating, just wondered what others done
also i have coilovers with no place to secure the brake line again what have others done?
cheers
Use a p clip Pete hold it in place nice and secure
bobhatton
Post by bobhatton »
Leakie Tbar wrote:The goodridge warranty isn't worth the paper it's written on !!!!
And the quality isn't as good as people bang on about,
The welds on the rear brackets are terrible quality
I had a brand new set fail on my n/s/r and I'm still battling with k300 over warranty to the point I've bought another set from a trader on here,
I had the same problem with one hose set. I rang Goodridge and had a replacment within days even before I had sent the damaged one back.
Leakie Tbar
I wish they had the same level of customer service now, !!
Fozzy
Post by Fozzy »
That's the difference between going back to the trader (normally useless) and contacting Goodridge direct. They are incredibly helpful when you go straight to them.
To the OP, I had do luck lines on my car, same as he HEL lines. I bolted a plate to the stock bolting locations, then drilled and tapped somewhere in the middle so I could bolt a p-clip in place. Use a proper stainless one with the rubber protector, it will hold the line nice and securely
Leakie Tbar
I've been direct to the uk supplier and to the USA, the USA where by far more helpful and replied within 24hr, uk where not
Leakie Tbar
pistol pete
Post by pistol pete »
Do you mean p clip round the coilovers or to hold the brake like in place?
Leakie Tbar
P clip around the flexi pipe union , it will bolt nice to the 12mm original mounting bolt for your rears
Nic
Post by Nic »
The Rogue braided lines also include the mounting brackets.
http://www.roguesystems.co.uk/forms/Product.aspx?ID=495
Nic
[email protected]
MR2 Rev 3 GT Turbo
pistol pete
goodridge lines fitted
really didn't want to cable tie them to the struts done have a clip for them
so made some brackets
Peter Gidden
Post by Peter Gidden »
Nice job!
gavsdavs
Post by gavsdavs »
yeah - nice improvisation - cable ties looked like a bad idea..
pistol pete
gavsdavs wrote:yeah - nice improvisation - cable ties looked like a bad idea..
cheers
trust me wouldn;t have run like it just would not have been happy, looked like it would rub.. i just needed to find what to do.. ths seemed the best option
fingers99
Post by fingers99 »
Keri-WMS
Post by Keri-WMS »
Leakie Tbar wrote:Image
That SUCKS, really odd failure...
Peter Gidden
Assuming you bought new from a dealer, the supplier is under obligation to replace. Then they sort out getting a replacement for themselves from Goodridge.
If you bought secondhand, then very few manufacturers offer a transferable warranty. And by buying secondhand, i presume you did not expect the same guarantee as someone who pays full price?
I have had nothing but 100% perfect service from Goodridge for 9 years+.
Keri-WMS
Post by Keri-WMS »
We get our lines made by Earls, Goodridge used to be their UK dealer but Earls then set up properly in the UK for themselves.
Not really sure if Earls still supply Goodridge but the fittings look the same to me!
HEL stuff is cheaper but they do things like use plastic line guides, or no line guides, scarey really as the brake lines are a car's achilles heal in my book.
