Heya fella
You don't say what you want from the car.
Comfort? Looks? Handling? You really need to decide purpose first then get the appropriate bits.
Simply put do you want it lower and firmer or the same as standard? If lower
it's coilovers or a set of lowering springs with suitable dampers.
You can lower a little with say Eibach springs and retain a lot of comfort or slam it low with Tein springs which look great and offer most body control but
offer no comfort.
You've then got to match them with a set of dampers.
for standard springs or Eibach/Apex etc I'd go Bilstein Black billies.
For the lower Teins I'd go with Yellow billies.
IF comfort isn't an issue.
Most things other than standard should lower you a bit since rev1s sit higher than the later cars anyway so standard springs for a rev 4/5 say should see a reduction in height.
Lots of advice to be had here on suspension but you really need to diecide what you're after first.
R
You can see my Rev1 set up in my garage but whilst its fabulous fun in the twisties its filling loosening pain on a potholed high street.
Horses for Courses.
