Engine management light comes on then goes off a few mins later
Jonny4494
Post by Jonny4494 »
Hi guys, driving down the motorway, my engine management light came on for a few minutes then went off again. What could be the cause of this?
Cheers,
Jonny
shinny
Re: Engine management light comes on then goes off a few mins later
Post by shinny »
It will have stored a code... check it! :thumleft:
Very little point us guessing at a plethora of possibilities when the use of a paperclip will probably massively narrow down the options.
Jonny4494
Post by Jonny4494 »
Will do :) what's the process to use the diagnostic box? Put the paper clip in first then turn ignition on? Or have ignition on before?
shinny
Post by shinny »
Jonny4494 wrote:Will do :) what's the process to use the diagnostic box? Put the paper clip in first then turn ignition on? Or have ignition on before?
Either will work :thumleft:
Jonny4494
Post by Jonny4494 »
Cheers bud, I'll give it a go tomorrow :D
