My PTP turbo blanket arrived from the USA along with my KO Racing 3" inlet .
Removed the x brace hot pipe , O2 sensor and the heat shield to get to the turbo . Snapped one of the heat shield bolts and O2 bolts
Was a bit of a pain to fit but after an hour or so it was all on .
All done up and heat shield back on .
Old HKS intake removed ( for sale on Ebay )
All set up ready to go on .
And DEI heat tape on the pipe .
All lined up and connected and tightened up .
View from side intake pod .
X brace and bits on to finish off .
Next will be a trip to Surry Rolling Road on the 14/06/14 to check AFR and see what power she is making .
Alan
Turbo blanket and KO Racing intake
Re: Turbo blanket and KO Racing intake
what size is your ptp?v thinking of getting one soon
T25/T28
Jonny4494 wrote:what size is your ptp?v thinking of getting one soon
Awesome, I've been looking at those blankets. Are you using the CT20 turbo? Any idea's if that blanket would fit a CT26?
I would get a T3 one, that T25 one looks a bit small
nathan.z wrote:Awesome, I've been looking at those blankets. Are you using the CT20 turbo? Any idea's if that blanket would fit a CT26?
Turbo says CT26 on it on the photo where the air filter has been removed.
Im running a CT26 hybrid on my rev 3 and the T25/T28 is what PTP said i need and it is a good fit .
Alan
Alan
Mr Bognor wrote:Im running a CT26 hybrid on my rev 3 and the T25/T28 is what PTP said i need and it is a good fit .
Alan
Thanks alan!
