Are you running the stock ECU and using pump fuel?
bobhatton wrote:I think the Rev 1 and 2 ran 8psi boost on 8.8:1 C/R then when the Rev3 went up to 12 psi boost the C/R went down to 8.5:1
So if you want to run at 15psi the ECU will be controlling on the knock sensor most of the time and you will have lower power.
I would use some octane booster, the NOS one is the best.
GreddyMR2 wrote:OK, finally car is running again.![]()
I still have no smoke at all, but I only drove about 100km.I hope it will be fine now.
But another thing, the car now idles like with aftermarket cams.And vacuum is staying at around
-35 when it was around
-50 before.
However, when I drive, it runs perfectly, sound is strange only on idle.
I check vacuum hoses, all looks good.
Idle valve connected, no error codes, everything looks fine.
What more should I check?
Here is the video:
https://www.dropbox.com/s/g0sltgdbl6807iu/VIDEO0040.mp4
bobhatton wrote:GreddyMR2 wrote:OK, finally car is running again.![]()
-50 before.
Here is the video:
Sounds like the cam timimg may be out, re check it again
GreddyMR2 wrote:bobhatton wrote:GreddyMR2 wrote:OK, finally car is running again.![]()
-50 before.
Here is the video:
God damn it..
You mean timing belt, right? But if it's working well when I drive, is it a problem?
I have N/A cams and cam gear on exhaust side retarded by 5
deg.
androo007 wrote:Thats about the same as a BMW then![]()
Sounds a bit much tbh.I dont use a drop
