bolton wrote:Using a walbro 255, 1000cc top feeds (racer x top feed kit), -6AN Redhorse performance fittings, standard toyota fuel filter, braided lines.
Also uprated the fuel pump wiring, removed relay and resistor.
We always use a dead head fuel setup as its called so only the fuel being used by the engine goes through the fuel rail, We then fit a10 micron filter on the feed to the rail with a 100 micron filter on the main fuel feed to the regulator.
All the lines and filters must be blown through before final fitting.
