Here's a little taster of how it looks.
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00196.jpg)
It came to us about 4yrs ago with a knocking engine.
Engine-
3.0 24v 3vzfe from a lazy old automatic Camry
Freshened up before install with new bearings, head gaskets, belts etc
Heads gas-flowed before been skimmed and fitted with new bolts.
Woodsport engine mount and front
Sump baffle added for those long right handers.
10w60 fully synthetic oil used since install.
Pulls well from nothing to the rev limiter, uses no oil or water.
Exhaust hand-made by me into Magnaflow back-box.
Cone air filter down by N/S air vent.
Porting, before-
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00437.jpg)
After-
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00436.jpg)
Engine sat in before been finished off-
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00495.jpg)
Exhaust before install-
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00508.jpg)
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00507.jpg)
And on the car-
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00511.jpg)
Transmission-
Std Rev1 n/a
MR2 Turbo flywheel redrilled to suit V6 crank PCD
N/A 4 puck race centre plate
TBH the clutch was a bit of overkill and is a bit
Suspension-
Polybushed throughout including ARBs
D2 fully adjustable coilovers, done about 3-4 trackdays and virtually no road miles.
Buddy Club coil springs, chosen for track as much stiffer than the D2 ones.
Geometry set for track use with 2.5deg neg camber front and 2deg rear.
It's handling is fantastic and the cars real party-piece on track.
![Image](http://i723.photobucket.com/albums/ww236/enicpic/MR2/DSC00777.jpg)
Brakes-
Rev2+ Turbo front and rear.
Grooved discs with EBC Yellows.
HEL braided lines and DOT5 race fluid.
Wheels
3 sets-
16" JDM staggered split rims fitted with Yoko 205/45 front 225/45 rear, used to drive to track and as
2 further std 15" sets fitted with 4x Toyo R888 225 rears and 4x Hankook/Michelin Cup Sport 205 fronts.
Interior-
Stripped but retains dash and door cards etc, easily put back to road spec.
Aftermarket adjustable
Full harnesses.
Momo steering wheel.
Car's been lightened wherever possible for track use but again in a way that can be reinstated.
Managed about 30mpg on little trip to Germany but mpg dipped slightly at this point
![Image](http://i723.photobucket.com/albums/ww236/enicpic/Ring%202011/meal2.jpg)
This is a great car built with help and advice from Peter Gidden
It's done a 14.0sec 1/4 at Santa Pod on road tyres.
The car's been dry stored this year due to other commitments but started first time the other week and was driven faultlessly between garages.
Serious enquiries only, no silly offers, car can stay where it is
![Wink :wink:](./images/smilies/icon_wink.gif)
Please don't ask if I'll sell parts off the car.
