Hi everyone,
Got a really annoying knock on my two. I have already replaced the top mount the bushes, drop links and ball joint. I'm all out of ideas now. Is there anything else anyone can think of? Thanks.
Sam
Front end knock
Re: Front end knock
How long ago did you replace all those?
Ive replaced my parts recently and got a knock along a few hundred miles later again
Re: Front end knock
Within the last two weeks or so
Re: Front end knock
If you're sure that no bushes have play in them and you've replaced everything else that could knock, you're left with one thing. Shocks.
I had a rear end knock that couldn't be pinned down for a while, replaced the shock with a known good spare and hey presto, no more knocks.
Re: Front end knock
Yeah I guess I should look into trying to find a shock. There really is nothing else I can think of. Thanks for the help.
Sam
Sam
Re: Front end knock
Gullzter wrote:How long ago did you replace all those?
Same story here actually. I had a pretty major clanging when going over uneven bumps.
I had drop links and ARB bushes replaced for the MOT back in December, which cured it completely, but it came back within a few hundred miles. Keep meaning to ask the garage to take a look and I'll post back when they have.
Surely drop links and bushes should last a lot longer than this!
Re: Front end knock
Sounds like they were Ebay parts and not from Toyota
Re: Front end knock
I've had new drop links come loose on the strut bracket causing a knock.
