Compression was good, lambda was OK, spark plugs are changed, all fluids are fresh.
Toyota dealer advised to replace MAP sensor and the flex-pipe was leaking.
Replaced MAP sensor but didn't pass.
Recently replaced the flexpipe and now the complete system is air-tight but ever since
Car is running fine.
The idle air screw is all the way in.
Also cleaned the TB inside out.
Before it will be at the dealership again I'd like to get some more clues.
There are not codes in the ECU
Im clueluess.
