I am currently making some pipe work up to fit my charge cooler - I need to put the small hump in the pipe to stop the silicone pipe work slipping off - can any one tell me what this process is called? I thought it was a "swage"
but apparently its not - I have tried a number of local engineering companies to get his done and am coming up blank. I am now resorting to telephoning other companies farther out and asking them but it would help if I knew the proper name for the process
Even better if your Near Wiltshire and can do this please drop me a line
[Mk2] [Turbo] new hot pipe
Re: [Mk2] [Turbo] new hot pipe
Bead rolling? That's what I'd have called it anyway
Think you may have nailed it there Mr. Beans. Thank you sir.
Bead Swage !!!!!! is what I am after - can any one help?
Diameter?
Mr. Gidden to the rescue again ! Thanks Peter, I'm off out to the garage to have a fiddle
slipping clutch wrote:Mr. Gidden to the rescue again ! Thanks Peter, I'm off out to the garage to have a fiddle
slipping clutch wrote:Thanks Peter, I'm off out to the garage to have a fiddle
its bead rolling
youtube it
its like a press that pulls out a small amount.
where to get it done though, no idea!
youtube it
a couple of beads of weld is all you need to do.
mark239 wrote:a couple of beads of weld is all you need to do.
as above,
Done this before on someones boost pipe. Just ran a run of tig weld.
Doesnt even have to be a ful fun, just a few beads to stop the clamp from blowing off
