Here's a couple of things the guy at Auber Instruments told me when I asked about using it as a charged air temperature gauge and it's accuracy:
Thanks for contacting us and your interest in our product.
You can use either SYL-1813 or SYL-1812RA.
The former one is the most commonly used gauge for monitoring air temp, oil temp, pressure, etc.
The latter one has a analog output therefore can be used for data logger.
You can find them here:
(link)
As for it's accuracy,
sampling rate
:4samples/sec
Accuracy: 0.2% full scale
+/- 1
If you look at item specifics on the eBay link the bit where it says New or Used Item, you can see under manufacturers part number syl-1830g
(g is for green).
Have a look at the Auber Instruments site under automobile gauges and when on there look at accessories.
I got a gauge
(syl-1813b as the rest of my gauges are blue), buzzer and aluminium box to put it in for
£61 incl p&p.
I'm going to use it with this: 22134770539nine
