Can someone recommend me a nice turbo kit, Im not looking for big bhp. Something fast spooling, preferably with an external wastgate. maybe a Gt28.
Thank you.
turbo kit recommendations
Re: turbo kit recommendations
Why externally 'gated? Just curious. I have a GT28RS and it's internally wastegated. I'm currently at a comfortable 312bhp/308lb-ft on 1 bar boost so if you're aiming for 300+ horses then I recommend it.
GTX28 or GTX30, nice quick spool with room for more power as and when you decide you want it
There is a company that makes a bolt on kit for the 28 range of turbos, it has an adaptor for both the stock manifold and stock downpipe. I cant find it now but I was looking at it just the other day.
I have bought an adaptor from ebay that converts from Toyota to GT28 size and am putting together the parts to do it myself. I am going to have to make or modify the downpipe as there is no space for an adaprot with the manifold adaptor I have. If you want to use a standard off the shelf DP you need to shift the turbo over a few mm to make room for a DP adaptor.
I am going for the GT28 as most of the ones I have seen have internal waste gates and for me thats a good thing as it saves on more fabrication.
The company that shalt not be named stocks a bolt on adaptor to go from the stock manifold to a GT28/GT30 housing, he does a downpipe for it as well. I'm sure he'd do the whole kit with a GTX turbo for you as well.
External waste gate all the way
Yeah, mine was done by Voldemort as it happens
I was a little tardy to the party and don't know any details of what happened (apart from him trying to kill Harry Potter) and I suppose that story will never be told again. His handywork installing a GT28 and associated plumbing is pretty sound though.
CURSE YOU, IMOC.
CURSE YOU, IMOC.
Thanks for the reply,
Im looking for a full kit for the moment, I will have a look On the voldemorts web site.
I had a screamer pipe on my supra with a T 61 and loved the sound, that's the only reason, I think it's meant to help exhaust gas flow as well, but its mainly for the sound.
JD wrote:Why externally 'gated? Just curious.
External gates are generally less prone to creep... sounds like a very good reason to me
Yep- better boost control full stop with an external gate
This thread might actually be usefull if I knew who you were talking about.
shinny wrote:JD wrote:Why externally 'gated? Just curious.
Might be something to take into consideration if I try pushing for 350 next year but I'll save that for another thread.
Well I run (or ran - the cars being stripped NOW) a GT2860RS with an external wastegate.
Superbly fast spool, fantastic noise off the screamer and good for around the 340 mark. no creep when used with a Profec B Spec ii, holds 12 psi at Lo boost and 17.8 psi at Hi boost perfectly.
You can hear the screamer nicely on this video. A highly recommended turbo for lightly modded tubbies
https://www.facebook.com/photo.php?v=659234227461799
other than the company that cant be named, where did everyone else get there kits from?
The Ko racing kit looks good.
http://www.koracing.net/viewproduct.php ... roduct=453
I have a full kit for sale still, GT3071R with top mount adaptor, you just bolt the whole thing on, even includes oil feed.
dazzz wrote:I'm no expert but
ashley wrote:You got PM
Could you also pm me,
Screamer ftw, though don't expect to be aloud onto a track with one!
http://www.youtube.com/watch?v=1y8W_WvLjpE
Even better, run no bov!
http://www.youtube.com/watch?v=KsnTSwfvWmY
jimGTS wrote:Screamer ftw, though don't expect to be aloud onto a track with one!
That does sound nice with no BOV
My TRD WIDEBODY build thread http://www.imoc.co.uk/forums/viewtopic.php?t=164957
