[Mk2] [Turbo] Superflex / superpro polybush kit
Rossi
Post by Rossi »
I've decided on this polybush kit, superpro/superflex are identical as far as I can tell with even the part numbers almost identical on both of their websites. I'm about 5mins from ordering but I'm struggling with the rear control arm to chassis bush.
Apparently my 1994 uses a 12mm bolt for the rear control arm but they only sell a rear bush for the earlier cars with a 14mm bolt show here.
http://www.superflex.co.uk/proddetail.p ... 30%2F14KSS
Does anyone know if the bush for the front control arm which is 12mm is the same fitment as the rear on the later cars.
http://www.superflex.co.uk/proddetail.p ... 30%2F12KSS
I don't want to have to order a full superpro kit but a powerflex rear control arm bush as powerflex offer the rear in both 14 and 12mm.
Mike
Peter Gidden
Re: [Mk2] [Turbo] Superflex / superpro polybush kit
Post by Peter Gidden »
I've sold 100s of ProThane chassis bush kits with no options for any of the control arm bolts. :?
Rossi
Post by Rossi »
http://www.powerflex.co.uk/road-series/ ... 233/1.html
Look here then, there's 2 options 12mm and 14mm? Confused now
PFR76-305 fits Rev 1&2 models 1989 to 1992 and uses a M14 bolt
Rev 3 models 1993 to 2000 use PFR76-305-12 which uses an M12 bolt
Peter Gidden
Rossi wrote:Confused now
Me? Not in the slightest.
Website is talking b0ll0x.
Rossi
Post by Rossi »
Well I am.
If you've only sold one type of bush kit but the bushes differ after 93 on the rear then that makes no sense.
Nevermind I'll just go with the powerflex rear bush
Peter Gidden
Rossi wrote:Well I am.
Let me see if i can make things clear for you, and show you the website you refer to is b0ll0x.
Here's a screen print from Toyota's EPC showing the rear control arm and rear tie bar bolts:
It shows two M14 bolts required, that will be one for each control arm. It also shows four M12 bolts, two for each tie bar. In both cases, the same bolts are used on all cars from 1989. No options of any sort.
So you can now be unconfused like me.
Rossi
Post by Rossi »
Thanks that was all I was asking. If you had simply said all mr2s use 14mm rear control arm bolts in your first post I would have accepted it, but your reply didn't really make it clear what they were apart from that the prothane kits you sell, fit.
