Anyway, regular readers will know that my radiator has started falling apart and will need replacing.
So
Also
Anyone got any recommendations?
Thanks,
Sam
HMV wrote:So- where's the best place to get a good, cheap radiator from?
Peter Gidden - SBITS wrote:HMV wrote:So- where's the best place to get a good, cheap radiator from?
"good" and
"cheap" rarely go together.
OEM copy for about£145, lifetime guarantee.
Cheap copy or cheap aluminium,£110ish, 12 month guarantee.
The cheap ones often have the bleed screw in the wrong place making bleeding a PITA, but it's no big deal.
Your choice.
Nic wrote:Peter Gidden - SBITS wrote:HMV wrote:So- where's the best place to get a good, cheap radiator from?
"good" and
Your choice.
Peter is there a radiator that you would recommend? Does the stock radiator use a copper core?
