Bilstein
tottacrolla
Bilstein
Post by tottacrolla »
Does anyone know if the standard fit Bilstein dampers can be re-valved as per most Bilstein products ?
Peter Gidden
Re: Bilstein
Post by Peter Gidden »
tottacrolla wrote:Does anyone know if the standard fit Bilstein dampers can be re-valved as per most Bilstein products ?
Not that i know of. And since the top of the casing is welded as opposed to threaded (like UK cars), AFAIK they are sealed units.
tottacrolla
Re: Bilstein
Thanks for the info Peter, much appreciated.
Nic
Re: Bilstein
Post by Nic »
You could try contacting Chris Wilson (trader on the Supra forum), he rebuilds/re-valves JZA80 Supra Bilstein dampers which I believe are similar to the MR2 ones.
[email protected]
Nic
[email protected]
MR2 Rev 3 GT Turbo
