When refitting the clutch slave cylinder, I had to push the cylinder into the bore to get it in place, does this mean the push rod is too long?
toecutter wrote:I adjusted that to get the amount of freeplay in the BGB spec, can I adjust it to get the correct bite even if it puts it out of spec?
