Hi All,
I've recently put a Rev3 Turbo engine into my Rev5 NA shell.
On the first few shakedown runs I'm a bit alarmed by the temperature in the engine bay.
I'm running a 3" decat, standard turbo, ASBO-spec Imotoria (on the hunt for something much quieter!) and standard pressures.
I've kept the stock turbo/manifold heatshield and have ordered some exhaust heat-wrap to help reduce the heatsoak from the downpipe. I'm also in the process of sourcing a turbo engine lid to help with cooling. The IC fan works as it should.
Anyone got any other tips that I can use to help reduce the temps? The NA engine lid is almost too hot to touch after 20 minutes of driving in normal town traffic.
Excessive engine bay temps.
Re: Excessive engine bay temps.
Turbo engine lid will help, as will a pair of engine lid fans
Is the spal fan working?
I have the same conversion on an NA lid and no issues.
I don't believe you need a turbo lid.
You can fit a single fan in the na lid if you really need to.
Someone on here has done this.
I've read up on the lid fan kits and I'm not convinced after reviewing the numbers.
Herts66 - have you removed the sound-deadening material from the underside of the NA lid? Also are you running stock cat/downpipe with heat shield?
millentubby wrote:Hi All,
How do you know the temps are excessive?
With a turbo engine lid your engine bat will be no different to 1000s of other near-identical cars.
Fair point Peter- to me they're excessive as the NA lid above the turbo is almost too hot to touch and you can see the heat radiating off it. Is that normal?
millentubby wrote:Is that normal?
Yep. Sounds normal to me.
Peter Gidden - SBITS wrote:millentubby wrote:Is that normal?
Normal to me mate
I'll have my car at work some day this week and you can see the heat if you dont believe.....
Updated IC, stock down pipe etc on mine with cat removed.
Sound insulation still on underside of the lid.
Not seeing a problem on mine.
Difference is a turbo engine lid is fiberglass not metal, so won't be too hot to touch
ashley wrote:Difference is a turbo engine lid is fiberglass not metal, so won't be too hot to touch
Also when you combine engine lid fans on a turbo lid, the turbo lid having raised grills has the effect of directing heat pulled out by the fans, to the rear of the car even when standing.
You can see this more so at standstill when it's raining and the rain is pushed away!
So when your driving your 2, the heat is already being pushed away is made easier as drag helps this further
Hence why for me personally, the phoenix power engine lid directs this further with the engine bay fans, such that when you stand behind the 2 on standing it feels like a hair dryer!!
When I fitted a Turbo Kit into my MK3 had the same problem, I then had the Greddy remapped and they put a racing thermostat in to reduce the temperature then my problem was solved
Dont know if it would work in your case but worth looking into
http://www.mishimoto.co.uk/toyota-racin ... stats.html
