Just got a SC! Few questions... :-)
Tsporter
Post by Tsporter »
Hi guys I just picked up an 87 SC. It's a Tintop with windy windows, no side skirts and came with no spoiler apparently( one fitted now) all from the factory apparently. Extremely happy with her so far but have a few noob questions. If anyone has more information on this factory model I'd love to hear it....seems rare.
Here she is:
- What grade of oil and spark plugs are recommended?
- The boot has some black gunk in the bottom below the ECU, what causes that?
What else would you look at for the first service? Ill give the coolant a flush and the brakes a look over. Timing belt was done.
Edit:- I found the SC oil dipstick and the level is fine.
toxo
Re: Just got a SC! Few questions... :-)
Post by toxo »
Can't help you but that's a fine looking car.
oukie
IMOC Organiser
Post by oukie »
NOT Factory,
looks like a car done by a member on here or perhaps the mk1 club, two or three years ago, if is the same car, you are very lucky, if I remember right it was very well done and the work carried out was done to a good standard.
More pics would help.
Chris
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's :)
Tsporter
Post by Tsporter »
oukie wrote:NOT Factory,
Chris
Car came here to Ireland from Japan in 2007 I believe. It is originally mica blue. Other than that, I'm looking for info! :-)
Tsporter
Post by Tsporter »
Anyone got a part number for a fuel filter?
I'm going with 90915-YZZJ2 for the oil filter...
Part numbers for spark plugs would be great to!?
coanda
Post by coanda »
Chris
Seems to be a copy of Chris' - his is a T-bar NA with white pin striping over the black.
User avatar
Lauren
Post by Lauren »
Oil filter is the same as pretty much every other Toyota. They all use a generic one. Easily and cheaply available from Toyota. There is a short one nad a longer one, you could go for the longer one but either will suffice.
Spark plugs need to be colder than standard due to the SC. Is it on a stock pulley?
If it was me I'd go to Toyota and get the appropriate platinum plugs for it. Chassis code should reap the details they need if you have a decent dealer. Price about £60 or so for a set.
Tsporter
Post by Tsporter »
Lauren wrote:Oil filter is the same as pretty much every other Toyota. They all use a generic one. Easily and cheaply available from Toyota. There is a short one nad a longer one, you could go for the longer one but either will suffice.
Thanks Lauren, yeah it's a standard pulley. Surely decent plugs could be gotten cheaper than that? Are they the same for the NA ?
Also where would I get a new drivers window rubber? Is it breakers only or do they do new ones?
P.s. I've been reading your posts for a long time and find them v helpful :thumleft: :thumleft:
User avatar
Lauren
Post by Lauren »
Well you just use copper NGK's. PCP7ES or PCP6ES, Mark said he can't remember! Which ones, sorry!
I prefer to use the correct OEM ones which will be platinum Denso plugs.
NA use a different heat range.
You could try Toyota for a new rubber, no idea if they will have any though. Don't know till you ask I guess.
I must admit, though I'm fastidious when it comes to using OEM parts whenever possible with my AE86, whatever the cost.
Send me a PM if you want access to the SC forum. :+:
Edit: NGK BCPR6EY-11 are the ones you want.
Tsporter
Post by Tsporter »
Cool thanks, ill head into Toyota first to see what they have...I think she deserves the best! :-)
Yeah cool ill pm you now, didn't realise there was an SC forum.
