More problems.
Last week I fitted ebay intercooler, new clutch and berk decat.
Just last night, I noticed at idle the revs drop to around 300 rpm and car stalls unless u give it some gas.
This is intermittent at the moment and only happened this morning at start up, then ran fine.
Intercooler seems to be ok.
Turbo is hitting full boost in every gear.
All pipes are good and tight with no obvious leaks.
Can't see it being a problem with idle control valve or throttle position sensor as I never touched them whilst doing any of the work.
No fault codes shown in ecu
There is a red wire that runs beside intercooler that comes from cockpit into engine bay then goes into boot.
Does anyone know what this is? It got tangled with fan belt and insulation was torn slightly until I realised and
cable tied it out of the way.
