Perfect if you are racing or doing track days in your car to ensure your getting the most out of it! we have used a lot of shift lights and found this to be by far the best, easiest to use and install.
so we have done a deal and are now stocking them.
Special introductory Forum price of
£75 delivered.
Valid until Sept 30th to order just drop me an email on
[email protected] quoting IMOC.
I will then send an invoice for payment
( paypal or BACS
)Comes with a 12 Month Warranty.
![Image](http://i1179.photobucket.com/albums/x395/seano_hurley/shifty_zpsfb0c2f29.jpg)
Most shift lights rely on the rev counter to program the shift points whilst revving the engine.
However, the SLD5 features a built in digital display to enable simple, accurate programming without starting the engine, eliminating the inherent inaccuracy associated with rev counters.
As used on our own Toyota Mr2 SW20 Race Car
Whether you have never used a shift light before or you are upgrading from a single lamp unit, you will find the information provided by the SLD5 invaluable.
By noting how many lights are illuminated at the entry and exit of any turn, you will know immediately where you have gained or lost time well before knowing your lap time!
Distinctive Features:
· 5 super bright lamps
· Built in digital display for easy set-up and data retrieval
· Individual or pair illumination for warning lamps
· All settings are programmable without starting the engine
· Shift flash facility
· User programmable
'shift light' set point
(from 3000 rpm to 20,000 rpm)
· User programmable
'lowest light' set point
· Intermediate set points calculated automatically
· Maximum rpm recall facility
· Shift lamp brightness control for night time use
- 6 brightness levels
· Compatible with 1, 2, 3, 4, 5, 6, 8, 10 or 12 cylinder engines
· Stall warning facility
- all five lamps flash
(slower than shift flash) if the engine stalls
· Anti-flicker system
- prevents lamps from flickering when approaching the shift point
· Can show the actual rpm on the display for setup purposes
· Non-volatile memory
- all data is retained even if the power is disconnected
· Ultra-compact size
- mount almost anywhere
· Extremely lightweight
· Extremely easy to install
(simple 3 wire connection)
· Reverse polarity protected
