Not too bad at all mate, you can drop the sump with the engine in the car still
(not that I've tried yet).
It's just an example, like having to decrease your oil change durations, etc.
I think the main thing is realising that you have to keep on top of your engine, lots of data monitoring, inspecting etc.
Once you significantly increase the power output, you significantly increase the potential for lots of very expensive engine damage if/ when stuff does start to go wrong.
.so it's key to stay on top of things.
The second you suspect something ain't right you need to chase it down and sort it, just in case.
Data logging is vital imo.
Totally worth it though
