As title, have taken out the rubber tipped bolt and the retaining clip, according to engine removal guides I read it should then slide out of carrier no bother.
I had to unbolt the support from the block to pull shaft from gearbox.
Bearing has a fair bit of play in it so I want to change it - am I missing a trick here or are they usually jammed in?
[Mk2] [Turbo] Driveshaft support bearing stuck in carrier
Re: [Mk2] [Turbo] Driveshaft support bearing stuck in carrier
toecutter wrote:As title, have taken out the rubber tipped bolt and the retaining clip, according to engine removal guides I read it should then slide out of carrier no bother.
You will need to press it off
Thanks the press did it.
