I fitted a set of Recaro's in my SW20.
What I did is get a set of Recaro sliders
(don't know if they are for some other car model, or the same for every car, at least they fit my seats).
And then I drilled and grinded the parts of the original rails where the bolds go in
(just bought some old destroyed second hand seats for this).
I welded those on the Recaro rails, and that was pretty much it.
Only things to take care about when you do it this way is that the Recaro seats are 2 cm smaller at the base than the original MR2 seats.
So you have to weld the parts from the orginal seats 1 cm off center to the Recaro rails.
And you have to come up with something to connect your seatbelt.
Got my connected to the bolt that sticks out of the middleconsole at the moment.
But it seems that is not a very good idea.
Altough a MOT inspector told me it will be perfectly fine this way and possibly even safer than on the seat itself.
