Is the coolant neck filler 19mm?
This one
could one of you knowledgeable mk1 guys answer me this
Re: could one of you knowledgeable mk1 guys answer me this
What dimension are you seeking Jonny ?
Do you want the dia of the little bit of vertical pipe below the cap ?
ID, OD or what ?
Peter
ID, OD or what ?
Peter
Hi Pete, I was wondering if the connecting water pipes for the filler on the mk1 were 19mm (ID)?
Mk1 pipes are around 30mm ID.
