Sooty wrote:You need some P6000s.I started with 6mm of tread and only the rear left wore to below the legal limit and that was on the outer edge only.
I didn't check my pressures tbh, so I think they were a bit high, which probably helped the wear rate.And I certainly didn't have enough power to get them spinning apart from on the left hander before the chicane
(and that was only that left rear).
I was using up some old P600s, but even with P6000s i would have still taken them down to the canvass as i had the car sliding on every corner, plus i was running 36psi cold
