Hi all,
Just been trying to wire in a second fan running off a relay switched by the IC fan. It didn't work so I put all the wiring back together for the IC fan but now it doesn't kick in when you unplug sensor which it has always done before I pi$$ed around with it. Now the EML is on as well.
Any ideas what I could have done and how to get it working again? Fuse is fine btw.
