Hi All,
Need some help.
I am currently in the middle of my mk1.5 build and have run into a bit of a problem. I have some bolts missing, that we can see.
Bolts needed:
Gearbox bolts
Flywheel bolts
Starter motor bolts
Does anyone know the sizes for these bolts? Or even where to get them?
Thanks in advance
Beckie
3sgte bolts
Re: 3sgte bolts
ill have a gander and see if i have some in my bolt store
do you need all the gearbox bolts?
and is it flywheel to crank or coverplate to flywheel?
Re: 3sgte bolts
Think I need both
- IMOC Committee
Re: 3sgte bolts
If you don't know the sizes or pitches and no one on here can help you can get them from Toyota... you will think they were made of gold though!
