How well does this fitment go ? I dont want to mess up the handling of the car.. will it fit ok ? or will I need spacers?
Thank you
17" 7.5 J ET 50 alloys and fitment onto an mk2 rev3 ?
Re: 17" 7.5 J ET 50 alloys and fitment onto an mk2 rev3 ?
Are they Lexus wheels by any chance? We went down that road and it didn't work. Could have done it with longer studs and spacers but we opted for proper staggered wheels instead.
they're veilside , currently on a celica , they have the same tyre sizes on each alloy too which im not sure is suitable for an mr2 correct?
they are Veilside Andrew Racing alloys
Libertine wrote:they're veilside , currently on a celica , they have the same tyre sizes on each alloy too which im not sure is suitable for an mr2 correct?
I'm sure a celica is 5x100 stud pattern, so wheels wouldn't fit unless you get some adapters
they are 5x100 , what is an mr2 size? 5x114.3 right ?
would i need 4 of these ?
http://www.ebay.co.uk/itm/JDM-R-Pair-of ... 4abfb68356
At ET50 I recall being told that it's something like 15mm up front and 20-25mm on the rear. But yes, you will need adaptors to run wheels with a different PCD.
Libertine wrote:they are 5x100 , what is an mr2 size? 5x114.3 right ?
You will need something like this:
http://www.ebay.co.uk/itm/H-R-PCD-Adapt ... 257a43d466
wow.. that is expensive! i'd be looking at £250 just for adapters!
walk away...that is Honda offset. waste of time getting them on a '2
