today i spent 2 hrs fitting my new poly engine mounts,
if there is anyone out there still running on standard engine mounts, change them the bushes cost me 50quid and 2hrs very easy work they make so much difference, really gives a punch on when hard revving as you can tell i am as pleased as punch really transformed my mr poo into an mr2 lol
poly engine mounts!!
Re: poly engine mounts!!
Got em and love them. Except the front one keeps pulling the bolt out of the engine/ tranny.
which bolt?? have to keep an eye out
I've done mine today. Massive improvement
nickg07 wrote:Got em and love them. Except the front one keeps pulling the bolt out of the engine/ tranny.
Not sure but if you hear a bang like a gunshot &p and then you hear a slight knock when you are on/off the throttle:/
It's not uncommon to have that bolt ripped out of the gearbox. Best thing to do is either drill & helicoil if available or just drill & tap out to next size up & use a new bolt. (Will have to open up the hole in th mount iirc)
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
I need to get mine helicoiled its a right pain.
What are the poly mounts like for NVH? I always heard that you stay away from them on a roadcar unless you like the whole thing vibrating on idle.
I noticed that fensport still have the TRD gearbox mounts available, assuming that their like the trd topmounts being a bit stiffer?
I mean yea the car does vibrate a bit at idle but...nm. I had poly inserts on my corolla t that also vibrated and it makes the engine sound louder IMO.
Liveable though.
Liveable though.
Don't bother with Helicoils - waste of time.
TimeSerts are what you need.
IMHO, uprated east-west mountings are pointless. They have no effect on the rotation of the engine due to torque.
agreed with peter helicoils are pants you may as well use blue tac,,
im still confused as to which bolt your all talking about?? i put locktight on all the bolts in mine,,
my car seems to be a little vibrant on tic over too but not too bad:)
Just my experience but I had my gearbox mount helicoiled nearly nine years ago and I've never had a recurrence of the bolt working loose
Agree on the east-west comment too. I bought a set of TRD mounts, changed the front / back mounts and sold the east-west mounts for nearly the same money as the full set! Definitely more vibration but far less movement. Gear change slicker too due to the decreased movement under load.
having a look as im going to do these
is there only 1 size for rear mount but 3 for front??
yes 3 different sizes for the front but can measure it relatively easily with a vernier i layed over the back an measured from the top:) i dont know if the size is relates to the model but im sure someone will tell you
can anyone tell me what size front i need, i read somewhere its based on dif rev's taking different bolt sizes
car is a 98 rev5 na
car is a 98 rev5 na
Agree with the above! A must do mod
where do you get them?
This is just the front and rear lower mounts? There aren't any others? I've not looked into it. They don't need changing?
I found powerflex ones on eBay for front and rear lower engine mounts.
There are 4, front and rear and sides
Front is 3 different sizes.
RikH77 wrote:There are 4, front and rear and sides
Where do you get them?
which ones rip the bolt out?
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
