rev1 and 2 - CT26 = 6 studs
rev3 - CT20b = 7 studs.
Edited so that people will look at first post in thread and see correct answer.
How many studs are there connecting the downpipe up to the ct20b turbo?
Thanks.
CT20b Turbo downpipe studs quantity
Re: CT20b Turbo downpipe studs quantity
Actually just read this
"ct20 only has 5 bolts not 6"
sorry should have done a more accurate search.
You accurate search is not very accurate.
7.
7.
Cheers Peter,
After reading your response I checked the thread I had found and sure enough further down the thread the guy is corrected and it is 7.
Just shows how easy it is to get misinformed.
So rev1 and 2 CT26 is 6 studs
and rev3 CT20b is 7 studs.
Peter, how would I go about removing one of the studs? Any special tools required?
Apologies again. Search and you will find.
Irwin bolt extractor socket
