[Mk2] [Turbo] Steering wobble at speed
Was cruising on motorway today and noticed the steering was very wobbly, dangerously wobbly. What could this be? Warped discs? When I let go of steering wheel it goes veers left and pulling left when braking (calliper stuck?) I know these cars are 20+ yrs old but surely it should handle a bit better
Re: [Mk2] [Turbo] Steering wobble at speed
There are 99 topics on this already - try the search facility.
Tried it, can't see anything
Has it always been like this? I would get the alignment checked and make sure the wheels are balanced.
Only bought it a few weeks back and didn't test it on a motorway. The front tyres are a bit worn on the outside too,is this pointing towards an alignment issue, do u think?
There is definitely an issue. Pulling when braking is likely to be a seized caliper(s), get the car on a lift and get the brakes, all the suspension components, tyres, wheels, wheel bearings, etc. thoroughly checked over. Also get the wheels balanced and the geometry checked.
Will do, do mr2's handle well even for the age of them these days? Is it a 4 wheel alignment I need?
joemacmr2 wrote:Will do, do mr2's handle well even for the age of them these days? Is it a 4 wheel alignment I need?
They handle very well if in good working order, you definitely have some issues, impossible to diagnose what is wrong over the net, you need to get the car checked over by an experienced mechanic.
Reading the 99 topics will really help.
I wasn't being pedantic, it really will!
Baker wrote:Reading the 99 topics will really help.
+1.
Could be: caliper, disc, wheel bearing, hub, lower ball joint, top mount, wheel, tyre, geometry.....
Spiggot rings?
Spiggot rings for the wobble? Haven't had wheels off yet so I'll check that. Cured the problem for me on a previous golf yrs ago
If the car pulling to left, is it the right or left caliper that may be seized. Lots of conflicting answers, people saying left, others saying right. I did have a look at brake pads and the left seems to have less meat on it, but I thought it should be the right caliper sticking to pull left
I had the same on my car when i first picked it up, awful wobble actually scary! Fitted the correct spiggot rings, wheel alignment done and it cured the problem. Just a thought worth checking if you have aftermarket wheels
Did u do a 4 wheel alignment?
joemacmr2 wrote:Spiggot rings for the wobble? Haven't had wheels off yet so I'll check that. Cured the problem for me on a previous golf yrs ago
Could be either. If it's pulling left, the left side is dragging, therefore the left hand side caliper could be stuck partially on. Alternatively, the right hand side caliper could be seized and not properly gripping the disc, meaning braking is stronger on the left causing you to pull left.
Most common cause of steering wheel wobble is wheels being out of alignment or not properly centered. Get some spigot rings if you're on aftermarket wheels, they cost a few quid and do a lot of good if your nuts don't perfectly centre the wheel. You just SHOULD have them, no buts. I'd do that first, since it's cheap. If it doesn't solve it, get your alignment done. To be honest, most cars on the road could probably benefit from good alignment set ups. If you've noticed your tyres are wearing wrongly, then you should DEFINITELY get this done and it will at least fix some issues. It will be pricier than spigots but don't skimp. Needless to say, take it to somewhere that uses a proper Hunter machine rather than your local Kwikfit. IMO.
If that doesn't rectify, consider that your alloys might be buckled, bent, or otherwise not running true. Visually inspect (the inside lips and barrels remember). Like others have said that could in fact be a problem with suspension components being misaligned or broken, rather than just the wheel. Unlikely, but if the car's had a bump, gone off the road, or hit a vicious pot hole...
Hopefully this helps a little. The operative point, is get in and take a look. Inspect your alloys and your tyres and they will give you clues. Fix what's cheap, and just work through it trial-and-error. Or, as Nic says, get a mechanic to take a look.
Thanks for info, left work last night and put car on full lock to the left and could feel the wheels hopping, as if something was popping out of its socket so I suspect ball joint, track rod end will be the first components to check
joemacmr2 wrote:Thanks for info, left work last night and put car on full lock to the left and could feel the wheels hopping, as if something was popping out of its socket so I suspect ball joint, track rod end will be the first components to check
snaped spring?? can cause that popping on full lock ,, you relly could do with getting it in the air and looked over ....
From what you've said the car sounds dangerous and unroadworthy at the moment - which strictly speaking could void your insurance. There could be many reasons for the vibration, braking and tracking issues you are experiencing, with the car on a lift, a decent mechanic should be able to quickly diagnose what the problems are, it may cost you half an hour in labour but at least then you'll know exactly what needs sorting.
Where are you located? there may be an forum member/trader local to you that could help.
My guess would be a seized upper mount bearing causing the spring to turn when steering, it's a common problem and very easy to check.
