![Image](http://i163.photobucket.com/albums/t293/madjester_album/Toyota%20MR2%20T-bar%20G-limited/MR2%20new%20Engine/CIMG2576.jpg)
Here's the pic of the Oil Squirters that im sure the NA 3S-GE doesnt normally have.
![Image](http://i163.photobucket.com/albums/t293/madjester_album/Toyota%20MR2%20T-bar%20G-limited/MR2%20new%20Engine/CIMG2590.jpg)
and i think i found the source of the odd knock clive.
![Image](http://i163.photobucket.com/albums/t293/madjester_album/Toyota%20MR2%20T-bar%20G-limited/MR2%20new%20Engine/CIMG2577.jpg)
rev3turbo wrote:Only the very early rev 1 3sge engines didnt have oil squirters, the rest do.Every na engine ive took to pieces
(alot) have had squirters, bar 1.
You'd know if you had a turbo block, there would be a nice big hole in the side of it
bobhatton wrote:
Its not a big hole, they just get a small crack in number 2 bore when they go, but only leak water on boost so would be ok on a NA
ashman wrote:3SGE engines do have have oil squirters bud
ashman wrote:Surely the easiset way to tell if you have an NA block is to just look at the pistons? If it's a turbo the crowns will be flat topped to lower the compression ratio..
.simples
Peter Gidden - SBITS wrote:![]()
Rev1/2 N/As do not have squirters.
rev3turbo wrote:Peter Gidden - SBITS wrote:![]()
Incorrect, ive took apart around 5 rev2 NA engines and 3 rev1's, they all had oil squirters barring one(one of the rev1's)
Peter Gidden - SBITS wrote:rev3turbo wrote:Peter Gidden - SBITS wrote:![]()
Fair enough, you're right, Toyota are wrong.
It seems that way yes
surely youve a spare rev2 NA engine lying around, get the sump off, ill put my house on it having oil squirters.suprised you not seen them before tbh.
