Apologise if this is already covered. I have used the search, but nothing conclusive. Can some one please confirm the correct spark plug gap for my mods?
Rev 3:
3 " Turbo back system.
Apexi Induction.
HKS Intercooler
NGK Leads
Running 1.0 bar on stock CT20.
Thanks.
[Mk2] [Turbo] Spark plug gap.
Re: [Mk2] [Turbo] Spark plug gap.
read my thread on...hesitation/stutter under full boost..the one under this...also the thread on http://www.imoc.co.uk/forums/viewtopic.php?t=133277
Only mention of a spark gap is 0.6 mm. The only mentions of gaps I've seen recommended have been 0.8 or 0.7. can any one confirm which one of the 3 gaps to use?
what plugs are you running?
NGK BKRE 7.
The higher the boost, the closer the gap !
I know this is an old thread but I'm trying to find out if there are any charts, or if anyone can tell me what the gap should be a certain boost levels.
I'm using HGK BKR7E plugs and running between 1 - 1.2 bar with a 205 charge cooler.
Any help greatly received.
double post
tripple post
I run the same plugs at the same levels of boost at 0.8mm gap with no issues at all. Just replace them once a year and all is well.
There is a very simple answer which covers all permutations of plugs, ignition systems, component condition and boost levels:
You run the biggest gap you can without the spark being blown out.
Simples
Simples
92 MR2 Turbo Rev2 stock engine, Link G3 TURBONOZ mapped, T78: 487bhp & 364lbft; 11.78@120. NOW BREAKING: www.imoc.co.uk/forums/viewtopic.php?p=1542658
94 GTiR: 12.08@115 TOTB Sold
92 300ZX: 12.6@113 (415bhp) 570bhp, 500lbft
00 Clio 172
05 WRX PPP
00 Clio 172
05 WRX PPP
stealth wrote:I'm using HGK BKR7E plugs and running between 1 - 1.2 bar with a 205 charge cooler.
I'd gap them to 0.7mm
cool, thanks guys
